Is there an Infiniti site with a microfiche?
CoastyAV8R
Car: 1994 Q45
I need to order a few parts that I have never seen since mine were missing. I know what I have but not what I need to put it back together again (Heater linkage, pins, etc) and if I had access to a microfiche, it would make ordering the parts one heck of a lot easier than me trying to explain what I need to a guy 2000 miles away.
Thanks,Pat
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ill look the stuff up tomorrow in the parts book.....
CoastyAV8R
Car: 1994 Q45
Thanks Wes. The part I'm missing is located behind the heat control motor and it's the linkage that goes to the air mixing door post that is about 6 inches to the right of the motor when it's mounted.
Pat
Q45tech
Such a common failure that every Senior parts guy will know.
elwesso
2007 BMW M Coupe
Pat heres the diagram...
elwesso
2007 BMW M Coupe
elwesso wrote:Pat heres the diagram...
Heres the part numbers... This was a little harder to recreate but all good
elwesso
2007 BMW M Coupe
If you look on the parts number diagram, the first number corresponds to the number on the parts diagram... Thats how you can tell which one goes where...
I had this exact same setup when I did the plenum, and it was invaluable
CoastyAV8R
Car: 1994 Q45
Thanks Wes, that's what I needed. I'm trying to get hold of Joe so I can order what I think I need. That's a great exploded view but I'm still a little foggy on what exactly I need since I don't know what it looks like when it's assembled. I'm pretty sure I need 27045EA and the spring that goes between 27045 and 27127U. I may wait until I go home and look at it again so I can be sure.
CoastyAV8R
Car: 1994 Q45
Thanks again Wes, I just got off the phone from ordering the part I'm missing and a transmission mount from Joe at Scottsdale Infiniti. After I sat there long enough staring at the view, it made sense of what I was looking at and after that it wasn't too difficult to figure out what part of the puzzle was missing.
elwesso
2007 BMW M Coupe
on yours, which one broke.....? What parts did you end up getting.
CoastyAV8R
Car: 1994 Q45
27127 is the part I'm missing. Everything else is there as far as I can tell, we'll see when I put it together.
