My right front wheel is not centered in the wheelwell. I haven't yet determined the cause but it has been suggested that adjustable tension rods will allow me to fix it.
However, all the adjustable tension rods I have found (which I'll list below in case anyone else is looking) have pillowball mounts in the front instead of bushings. I'm not crazy about giving up alot of ride quality since my car is a daily driver.
Does anyone know of an adjustable rod that uses a bushing in the front ? I'd prefer the stock bushing size (for Nismo bushings) but I'd like to see any. Thanks.
The ones I've found so far:
SPL tension rods S13/Z32 $161
http://www.splparts.com/S13/Suspension/ArmBush.asp Adjustable front tension rods allow adjustment of front caster. Our tension rods feature solid spherical bearings (rod end) instead of mushy rubber bushings, main rod is mirror polished Duralumin (A7075) and buckle/nuts are plated steel. Supplied with nuts and bolts.
Project Silvia $180
http://projectnissan.com/PRODU...t=608
Battle Version $210Battle Version Tension Rods are made with chromoly ends and DOM tubing. The sepherical end is teflon lined to give it long lasting quality and performance without making noise.
http://www.store.yahoo.com/pha....html
Tein Pillowball Tension Rods $210TEIN TC rods are constructed of carbon steel body with pillow ball end links. Weighs just alittle under 3 lbs each rod. Please choose your model when ordering.
Kazama $225Adjustable pillow ball tension rods from Kazama, comes with dust shield at the pillow ball ends like no others on the market. Very good quality surface finish.
Cusco $293
http://projectnissan.com/PRODU...t=289
JIC $315
http://shop.store.yahoo.com/ph....htmlImproved steering response, Improved handling under acceleration and braking. Precise caster and wheel base adjustment. Comes with high quality spherical bearings. For race use and street use.
And Stillen, which are just way too much.
