pulsar gtr wrote:HI nsrZ32,
Thanks for you help man, I will definitely call Concept Z and get some pricing and definitely will mention your name.
Regarding the engine and verifiying it, I went to my local Nissan dealer but they have no info on how they can track the manufacturing date from the engine serial number.
I even called Nissan Canada, and these people are clueless.
Does any one know if installing a FMIC ON Z32 might cause the car to run a higher temperature due to resitriction to the air flow to the Rad? I have heard few things, but I would like to hear it from some one that is using FMIC on their Z32.
Well Coz (concept Z owner), someplace like courtesy nissan, or most likely somebody on the forum here should have the means to help you decode it to find out the info.
As for the FMIC......lots of people will say a lot of different things about what you can and can't do on the Z32. Trust me, I know, I've heard all of it lol. But for what its worth, I've done a lot of things that you "can't do" on a Z32 and I've seen very good results. Pretty much its just that the Z community in a lot of places is set in their ways and once they find something that works they just stick with it as opposed to finding something that works better. Obviously on a stock Z sticking something like a big FMIC infront of the radiator is going to restrict flow, but if you have the grand plus for a good FMIC then your car mostly likely won't be all stock. Granted my layout of the cooling system is far from stock (Koyo aluminum race radiator, billion thermostat, aluminum lower hard pipe, samco hoses, eliminated heater, redline water wetter, nismo radiator cap, no AC in the way, etc) but my car runs cooler with the different cooling system and the FMIC than it did stock. I wouldn't try it on a completely stock Z, but on one that's been worked over, it functions wonderfully. If FMIC's weren't any good then why would 99% of the turbo cars out there run them? Anyway, if you want specifics on my setup, how it was done, pictures, whatever...just let me know and I'll put a bunch up on here.
Best of luck and let me know any questions that you may have.
