is there a way to prevent an aftermarket downpipe from hitti
wzntha
CoupedUp
Car: 1993 Coupe
Yea, my downpipe didn't start out doing this but it started to.
I made a bracket that helped pull the exhaust toward the transmission with a rubber donut hanger.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
My Greddy DP doesn't do this. It has a bracket welded on it though so it attaches to the trans, like the stocker does. Do your DP not have this bracket or something?
Hijacker
Car: '92 240sx Convertible
'94 F-150
More than likely this is a cause of the type of exhaust you're using rather than the downpipe itself. I have a generic ebay downpipe and have not had any issues with clearance. I am, however, using a BRM exhaust. A properly set exhaust will keep the cat in the proper angle, which will then keep the downpipe at the correct angle as well.
aznrib
Car: 1995 240sx
yea the downpipe is the issue. The flex section is known to hit the frame rail depending on where the flex is placed. if it is near the bend then it will hit but if the flex section is near the back then it should clear. I would get another downpipe or get something to pull it. The more it vibrates the faster things will become loose.... exhaust mani, turbo elbow etc.
wzntha
Hijacker
'94 F-150
The mount for the downpipe is connected to the trans mount. There's usually a small bracket that comes off of it. I don't have any pictures of it to share, though.
wzntha
slow s13
Car: cars, photo, music
it bolts on so it is possible yours is missing
wzntha
thenephilm
why cant you u just the frame and replate it back in..
Tulsa_S-13
Car: 1991 SR 240sx
thenephilm wrote:why cant you u just the frame and replate it back in..
Haha what?
thenephilm
well, in my world (more of a truck guy), if something is hitting the frame and it can't really be moved, you could always notch the frame and use pieces of plate to weld back in to add strength back into that area...doesn't sound like it hits really bad so I wouldn't suspect you would lose any strength in the front clip esp if you gusset it in right..just a thought..
wzntha
thenephilm
that might be able to work if you can get enough play out of them..
