Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Dec 16, 2006 6:44 pm
you could try to rig a switch like in the coupe/fastbacks. But a quick way to do it doesn't exist.
as far as your pass door not switching the light on, sounds like a bad door ajar switch/disconnected door ajar switch. If you look right above the striker, there is a black oval piece with (best description) an accordianed circular piece. That's your switch. It's grounded by the screw that holds it in place. Check it to make sure it's grounded (aka screwed down tight), there's no corrosion on it and that it's plugged in. If it still doesn't work, try your driver side switch on your pass side plug. If it works then, get a new switch.
