kazuo wrote:I had a SR20DET motor.
I had a KA24E motor.
I had a JDM CA18DET Digital Cluster, a KA24E Digital Cluster, and a KA24DE Digital Cluster.
The CA18DET tach and the KA24E tach worked on my KA24E motor. The KA24DE did not.
The CA18DET tach and the KA24E tach did NOT work on the SR20DET.
So, either you are all confused (cus CA tachs dont work on a SR. I would assume the reverse is true) or the CA18 has some sort of magic trick it does to make it work.
IIRC CA18DET and KA24E share the same tachometer signal. People with 89-90 240SX should not have to swap tachs. If you do you must have wired it up incorrectly.
umm, nope. All twin cam tachs work off the same signal (16bit IIRC) I'm 100% sure of it:) so I'm guessing you were confused about what tach you were using where. I have used both a CA18DET JDM cluster and the USDM KA24DE cluster on my CA. Worked fine...
The KA24E cars with swapped CA's around Orlando did not have working tachs until they put DE/JDM tachs in (Nismo1182 is running a JDM SR tach and it worksfine). I have no idea what you were doing, but your information is wrong (about the tachs at least, your speedo info is correct:))
and yes CA tachs work on SR's. which again leads me to believe you didn't have a CA18DET tach.
Sean
