TDot wrote:My personal suggestion...based on what I did with a radar detector...dont connect to the power on the rear view. Just run a wire down to the drivers side fuse box and tap directly to a fuse. It will look cleaner than splicing the rear view mirror wires...although easier. And the wire tucks right into the headliner (15 min). Either way, good luck.
Agree with TDot. Even though I went the easy route, my dashcam wire is tucked up into te space between my headliner and windshield. Given, I did not wire it to a fuse, I just tucked the wire all the way around and have it tucked away into the center console. But again, TDot's idea sounds better than the mirror. I'll be following too!
