Ok so I just did a search feature, never before have I seen a bigger collection of various solutions to this problem, none of which seem to make me feel confident that it will definitely work. Sorry to open this can of worms yet again, but it's not very clear. Here's what I found on the board.
Suggestion 1: "no its at 112.. and you cant snip a wire... you have to have the ecu re-tuned" This says to retune the ECU.
Suggestion 2: "Removing Speed Governor/Rev Limiter on 240sx Article."
http://www.240sx.org/faq/articles/spdgov.htm This seems to be about the S13, says in the article it may be different for S14. Just how different is it on a KA motor?
Suggestion 3: "Unplug the 5th gear position switch...the ECU limits the revs to 5000rpm in 5th, or relies on the speed sensor to limit it to ~116 if it's connected." Ok, great, is it the same for the S14? Where is this switch?
Suggestion 4: "Greddy Speed Limiter Cut (SLC) controller Type-A universal for Nissan/Toyota vehicles. Wire in the SLC to get rid of the factory speed limiter. $69.99" A waste of money?
Suggestion 5: HKS Speed limiter Removal. See 4.
So what's the best DOCUMENTED way to do it on a 95 and above KA 240 MT????? Maybe this can help clear it up for everyone. Thank you.
