Is there a single driveshaft conversion for 97' D21 with KA2
aws140
Car: 97' Hardbody
I have been trying to search and research to find the answer to my problem, but I can't find solid information.
I have a 97' D21 with: KA24, regular cab, short bed, and 5 speed.
My carrier bearing needs replacing, but I would rather just ditch the 2 piece shaft for a one piece as long as it isn't too expensive.
Is there an option for a single shaft from a newer frontier? From what I have gathered my wheelbase is 104.3 in, or 2649mm, which is the same for newer frontiers. I just have not been able to find out if there is a single driveshaft for these models.
I would assume that a single shaft from any frontier with the same wheelbase would work, but I would like confirmation before I go spending money. I am a broke full-time college student, so being frugal is a necessity.
I want to try this approach rather than having a driveshaft made.
Any help is greatly appreciated.
PEZi
as far as i know no one makes one... but it would not be a hard job for a custom driveshaft shop
longtooth
Car: 89 d21 HB
I would expect it to cost around $150.00 to have one fabbed. Had one done for my K5 7 years ago and it was $130.00
aws140
Car: 97' Hardbody
That's not too bad. Most prices I have seen to fab one were in the $250+ range. I may need to call some more driveline shops.
longtooth
Car: 89 d21 HB
Well I am also in oregon dont know if it makes a differance. The mom and pop business are the best ones usually to deal with then the big corp ones.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
where did you get yours converted to 1 piece that cheap? I am in WA (Seattle) and drivelines nw was telling me at least 400$ to make a 1 piece custom driveshaft. so i just went ahead and bought that center carrier bushing for 40$ and replaced my worn out one.
longtooth
Car: 89 d21 HB
Didnt do the one peice fab but had one made longer which is basicly a new one with the end pieces weilded on place and ballanced.
The place I went to was driveline specalties in delta park in portland oregon. They do alot of racing and industrial stuff also. I have used them for my drag cars and 4x4's. Havent needed anything done in 6 or so years but their work is pretty freakin good everytime I have used them.
longtooth
Car: 89 d21 HB
EstoMax wrote:where did you get yours converted to 1 piece that cheap? I am in WA (Seattle) and drivelines nw was telling me at least 400$ to make a 1 piece custom driveshaft. so i just went ahead and bought that center carrier bushing for 40$ and replaced my worn out one.
I would have done the same. You cant beat $40 bucks.
dvdswan
this is interesting, my 96 has a single shaft.
aws140
Car: 97' Hardbody
dvdswan wrote:this is interesting, my 96 has a single shaft.
It may be a 4x4 vs 4x2 change. Mine is a 4x2.
dvdswan
thats strange, I can see there being that much of a difference
Chezelle
Car: 1997 2wd Hardbody Truck
Greetings,
New member and my first post...I also replaced my trucks center support bearing at 150K but I'm going to try the swap to a single shaft hopefully before the U-joints need replacing if I can find one:
Here's a good article but for a 4wd...should be similar for a 2wd.
http://nissannut.com/projects/Driveshaft_rear/
I have the 97 2wd standard cab too if anyone knows the single driveshaft measurement for a standard cab 2wd it would be much appreciated for searching the boneyards!
Brian
bluedog
Car: 2009 Xterra Off Road
Converting to a one piece driveshaft on a 2wd won't work as it will hit the cross member that the carrier bearing occupies. It is not hard to change the carrier bearing anyway.
