My question is can I do the same with the ABS sensor so that my ABS light will go off? If I can what resistor do I use? And would I wire it the same as with the EGR and detonation? Thank you for any and all answers.
Thanks for your input guys. DCaff300zx, I've seen a couple guys delete the ABS. All it does is make the brakes manual. Check out this video to see the ABS delete block by Infinite Machine Concepts, https://www.youtube.com/watch?v=RvDwryuZyegDCaff300ZX wrote: ↑Mon Jan 28, 2019 11:46 amWelcome!
Not sure about anyone else, but I myself would not be modifying or changing anything with the ABS system, or especially deleting it. Never heard of doing that either, so not sure if there's any help truly available...other than advise to not do it.
NolimitZ32, I might take you up on that. Of course it would depend on how much it is. And I think I am going to try to figure out how to "Hotwire" the ABS to trick the ECU into thinking it is still there. As soon as I get the delete block in and the ABS out, I'll start running some tests and will post the results on here.NolimitZ32 wrote: ↑Tue Jan 29, 2019 7:40 amI have a working unit if you want to buy it. PM me. As for the resistor fix, cant help you there, never explored the possibility. If you do figure something out please do post up some info. Thanks.
