andrave »
https://forums.nicoclub.com/andrave-u6358.html
Tue Dec 07, 2004 5:11 pm
the piece that has the latch that holds your door shut is plastic with a threaded body that goes through, and a plastic nut threads onto it. Its pretty common for them to break. I always keep an extra at my house because they fit in your pocket when you are at a junkyard. they are a ***** to get to and to replace, because you have to run the cable to them again, but its not something that an hour and a friend to help get it working again can't fix.
