TViking »
https://forums.nicoclub.com/tviking-u26259.html
Mon Jan 26, 2009 8:38 pm
Before I get badgered about just fixing it, I will preface that this pertains to a Florida garaged, maintained, pearl white 94' Q45t that I have had for the last eleven years and everything works perfectly. It's stock in every respect except for Tokico Blues and a front tower brace. I'm not trying to jury rig, I just want to spend the remaing $ this car deserves in the right area.
Over time when first starting the car I noticed a quick high pitched groan coming from the right front fender area. It only happend when cold and went away. Well gradually it got worse and when I put my hand on the TCS actuator I could feel it giving a quick grind noise. Now my Slip and TCS Off lights are on all the time except for when I do a cold start and it occasionally resets, does the grinding sound thing again from the actuator and then turns the "Slip" and "TCS off" lights on.
I'm just starting to investigate using Alldata and other info but I greatly suspect the TCS actuator has gone south. If I do diagnose that the TCS actuator is bad, is there a way to turn off the lights "Slip" & "TCS Off" without disabling anything else?
I live in Florida and the ability to prevent rear wheel spin is hardly a concern. This car has the Hicas and I obviously want to keep ABS. Is there a simple fuse or relay pull that will turn off the lights?
I love my Q but buying a new $$$$ TCS actuator is not going to happen for this old BMW beater.
