Is there a parts number listing..
AG-M35
Car: 2006 M35
Is there an engine parts listing for only the 2006 M35 base?
There's a site called Amayama.com that has parts pages but so much to sift through.
The FAQs have a lot of great info, but the more you read, the more you have to read.
I have a 2006 M35 base that just turned 120,000 M . (Build date was Aug 2005) I have valve cover leaks and want to
refresh the top of the engine, maybe the valve position sensors also. There are no engine codes to deal with. I just want everything at hand when I need it.
valve cover gaskets
Spark plug coil seals
Intake plenum gaskets (metal?)
PCV valve
PCV hoses (Crossover and other ?))
Spark Plugs (a specific heat range for M35 is required on Infiniti parts sites, really?)
NGK-nnnnnn?
and anything else anyone might suggest..
Thx
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Go to InfinitiPartsDeal.com and plug in your VIN. With the VIN the site will only show you parts that fit your exact ride along with supersessions. Their drawings and database are the same as Nissan/Infiniti DPC.
AG-M35
Car: 2006 M35
Many thanks
VStar650CL
Technical Expert
:dblthumb:
AG-M35
Car: 2006 M35
Sorry
What about the Spark plugs (OEM = ? NGK #)
VStar650CL
Technical Expert
See MA-21 here:
https://www.nicoclub.com/service-manual ... 5%2Fma.pdf
Nissan usually only specifies plugs by their own part number in the parts catalog, but the Maintenance section of the FSM gives the OE number. In your case the stock plugs were NGK PLFR5A-11.
