ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Feb 24, 2011 11:09 am
A used QX4 is the only way to buy it, let someone else take the depreciation hit. At 14 yrs old my QX4 is running like it was 1997. The boards have been reinforced, the rust is minimal since it is Krown rust protected every other year which protects the wiring too.(A crucial must do)
Compression is as new, no leaks on engine, transmission, transfer case, pumpkins. Front end is clean, suspension is solid. Every 60,000 miles or so front struts, rear shocks last 2 150,000 miles. Rad is original with no repairs just every other year drain refill.
Rear brake linings are original, but expect to clean, grease and adjust
Front brakes depend on your driving habits but I get 70,000 miles on pads no rotors. Watch CV joints and rubbers. Look very closely at the CV rubbers, they will weather but mine are original 1997.
I think the first QX4 was over built, it matches the geometry and link and metal sizes of a 3/4 ton Ford or GM.
Although the way the front wheels assemblies are mounted with a circlip holding them on seems mickey mouse they are robust.
The 4 WD drive system is adequate, but use common sense.
The back seat sucks the big one, but I'm in the front.
The drive ability, comfort, position, line of sight, handling, stopping ( very good with ceramic pads) rear view, height are all good.
The rear windshield wiper control is in a bad position and you will have to dismantle the rear wiper and lubricate if never done.
As long as the vehicle is rust protected it will last. At 14 years it has to go 6 more to catch up to my Bronco, and I think it will surpass that Ford.
I maintain this QX4 every 3 months with every 2 years a total fluid change.
The vehicle you buy will most likely not have the kind of maintenance that is done to mine. So do your due diligence during the inspection and buying process. Know what you're looking for and look with your eyes wide open and if you fall in love with a particular vehicle, step back, deep breath, walk away and then turn back and remember that it is just a 4 wheel bucket of bolts. They make them by the 1000's.
Take your time!
If you are like me, I buy a used car with my tools. And that includes a set of ramps, compression gauge, bright light, a few hand tools and a hammer and chisel. I go under the prospective vehicle with the owners permission and take the front wheels off, jack up and examine everything.
If you are not that much into the DIY, have a trusted mechanic inspect the potential new buy. At any rate it will cost time or money to approve a new vehicle purchase especially a pre-owned, used, not so new, reconditioned, buy out or daily rental.
A good buy may be had by buying a returned leased vehicle with warranty left on it, or buy an additional warranty. Just be aware!
