Is there a low fuel sensor control unit?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I made a post about my low fuel sensor not working and I was told the FPCU has nothing to do with the low fuel sensor so then I looked to the 1994 q45 service Manuel and I found no Low fuel sensor control unit so.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If you are asking about the fuel level sending unit, read Tangalora's benchmark fuel pump replacement post in IOM.
GseaQ
We've had a '92 for more than 7 years and have never seen a low fuel light or message. I run the tank down to the last 1/2 gallon of gas and nothing. We just bought a '95 and while browsing the owners manual saw a notation about it displaying a low fuel message on the message centre. I ran it practically empty to get an idea of how the gauge reflects reality in the new car and didn't get any low fuel message. Has anybody ever seen one?
Glenn
96Qowner
Car: 1996 Q45
I get the low fuel message spontaneously. The Q display can be kinda erratic.
I rarely run the tank that low, but I do think I've seen it come on. It's calibrated to about 4 gals, IIRC.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
96Qowner wrote:I get the low fuel message spontaneously. The Q display can be kinda erratic.
It is around 3 or so, depending on how bent the sender arm on installation of the fuel pump.
Wise owners never go below ¼ tank for extended pump life.
Q45tech
Entirely separate sensor from gauge sensor, just a tiny metal cylinder with an internal float that grounds a wire when ~~2.5 gallons remain so 19.5 gallons consummed.
Everytime I replace the fuel pump [twice] the oem sensor gets more inaccurate.....................it has been 97k since last pump and a real 1/2 tank shows 1/4 on inside but the low fuel message still works or it did 3 years ago.
qship96
Car: 1996 Infiniti Q45
[QUOTE=96Qowner]I get the low fuel message spontaneously. The Q display can be kinda erratic.
I have noticed the same issue recently,only when freezing outside,upon startup on inclined driveway-even with over 1/2 tank of fuel {gauge reads correctly},message goes away upon driving a few hundred feet.....I then put iso-heet in tank and message doesnt come back ....I wonder if a small amount of water in fuel is freezing causing low fuel warning sender to stick?
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
I've actually ran out of gas due to the silly hose that starts to leak (too much fuel pressure kept blowing the hose). I didn't see any warning light or message (I don't think there is one) ... The steering just became hard and luckily the car could do another 25 feet for me to be able to park in a parking lot. Then it died. This is on my 93 Q.
Maybe it could but I had the BRAKE PADS WORN/TAIL LIGHTS INOPERATIVE signal on my message display and it blocked it from any other messages.
96Qowner
Car: 1996 Q45
Mine gives me false low fuel messages, no matter the season.
But, same as yours, it goes out after a few seconds.
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
I usually fill up at about 1/4 or 1/8, but I have seen the "low fuel" warning with an illuminated gas pump, if I'm not mistaken.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
96Qowner wrote:Mine gives me false low fuel messages, no matter the season.
I get the same thing... There are certain things you just live with in Q's.
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
I got the low fuel light a 3 or four times when the tank was above half. Have not got it since replacing the alternator after it went bad 2 months ago.
qsiguy
Car: 1994 Infiniti Q45 Turbo
Never seen that message in all the years I've had mine. Is this elusive message in the message center or an idiot light?
96Qowner
Car: 1996 Q45
It's on the right, where the trip mileage displays.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
96Qowner wrote:It's on the right, where the trip mileage displays.
Or on the left, if you have a JDM car....
