Is there a diffrents between the Infinity sr20det and the nissan sr20det?
nissanboypoa
Car: 1991 Nissan 240sx
I was wondering if there is a diffrent's between the nissan sr20det and the infinity sr20det because i want to put a sr20det in my 240sx and i found a place that is selling the infinity sr20det with waterpump wiring harness ecu, ect but i don't want to spend the money if it will not work and according this site this engine is only for the infinity g20 can you let me know if there is a diffrents?
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
there might be a difference in the intake manifold. I know there is a difference in the exhaust manifold. The G20 is FWD and the 240 is RWD so the engine might have to be modified to fit the RWD platform
steve s14
the head is different and so are the manifolds ( exhaust and intake). i'm sure there are other differences too but those are the ones that i'm sure of.just buy a rwd sr for a rwd car and you'll be much happier.
The Infiniti never had a SR20DET, it has an SR20DE.
The engines are completely differerent and WILL NOT interchange.
nissanboypoa
hey thanks for all the post's it helped here's the link i found according to the site i want to buy the engine off of it say's (and you can check it out) that the engine is a sr20det but it comes with a awd fwd trans http://www.godzilmovies.com/fr...1.mpg
nissanboypoa
ok so the link didn't work sorry tigerjapanese.com/product_info.php?cPath=44&products_id=223 try this site if it works
harlock_ssx
Car: 1993 Nissan 240SX
AZhitman wrote:The Infiniti never had a SR20DET, it has an SR20DE.
Not totally true...the Infinity G20 DID have to option for the SR20DET here in Japan, although the US models didn't.
FWD SRs cannot be used in a RWD application...completely different! You need to use a Silvia or 180SX motor in your 240SX. A FWD SR can be used in the Sentras & G20s though...
My bad - My point was that the car you refer to is a Nissan Primera (IIRC), not an Infiniti.
Good advice on the RWD vs FWD issue. Completely different engines.
