is there a difference?
dppflyinhawaiian
im just wondering, if i were to buy an s14 with the ka24de engine with an automatic transmission, would i have to change the engine as well if i were to do the 5 speed swap with the transmission? can i use the same engine that was hooked up to the auto transmission? or do i have to get a new engine as well? im pretty sure i could use the same eninge, but just wanted to double check.
thanx
S13_love
You can keep the same engine and just do a 5 speed swap.
kanye240
Car: 1990 Nissan 240sx Coupe'^2001 jeep grand cherokee
try lookin at this thread and good luck
zer...-look
dppflyinhawaiian
thank you very much that link and the nico write up of it was very helpfull.
but so i dont need to change the ECU or wireharness for a manual transmission ECU and wireharness do I? if there is such a thing.
thank you
Drift40
Car: 96' 240sx se
I did this swap and im just running the auto ecu. you dont need to use the 5th gear sensor or neutral position sensor either.
