is there a difference between the z32 tt and non turbo transmission?
dave37905
Car: '97 Nissan 240sx + '89 2-tone terror
i want a z32 transmission but i was wondering if the twin and non turbo transmission's are different such as stronger gears or different ratios?
Spddracer
Car: 1990 300zx twin turbo
The gearset inside is identical. Only the bellhousing has a very slight difference in size.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
the bellhousing difference is mainly the starter. if your running a TT flywheel with a NA box you have to shim the starter a little bit.. Its a difference of only a few mm and generally its not abig deal at all!
