no autodimmers here.vimyJ is right. for the weight of the car a more powerfull motor should have been put in it for stateside, but I'm sure price and emissions had a lot to do with it.alexhho wrote:Mayhem. Your 93' J30 had autodimming mirrors? I thought the guy above said they are only available on the 97 and 97.5 models? If your "sucks," and it was the 93 model, did Infinity improve them for the later models?
It would have been cool to offer a 6 and an 8. The 3.0L is not a slow poke by any means but when you feel the way this car handles you just want the power that the chasis can obviously handle. The torque comes on slowly with this motor peaking at 4800 rpm. If you manually control the transmission and keep the rpms up, the throttle response and power are great. Rember, this is a high reving engine in the 300zx veine. I remember looking at a table of stats about Nissan engines. The J's 3.0L appeared in a lot of different vehicles. Even in the Pathfinder. They all had different tunings or valves (2 or4 valve per), different cams, varialbe or non variable valves), etc.Mayhem_J30 wrote:
good point. i noticed that on mine as well. from idle up to 3000 the exhaust drones through the cabin pretty bad, but at 3000 it is probably at it's quitest, excluding idle. shortly after that it hits the powerband then starts to scream a wee bit. hehediamondj30 wrote:yea they could have did better to give us the 4.1 too.i put 436 gears in rear end it helps.it never kicks down on hills now.it stays in the power band better.shifts alot less on freeway and streets.it turns about 3000 rpm on freeway.makes the exhaust less noticable on freeway.
I've never had a set of yokohama's on any car i've owned. But I'm going to stay faithful to the Michelin PIlots I'm running now. They're soooo much better and quiter then the Firestones that were on it when I got it. I think the tirerack has a rating for road noise. It's a great way to compare tires. I believe your window problem is being addresed in another thread.alexhho wrote:Thanks for the tire info, VimgJ. I have Michellin tires on mine, but will have to replace them soon. People have suggested that the Yokohama tires run a lot more quietly. Is this true? I can't see any other tires run more quietly than the ones I have now. Take care.
Thanks, VimgJ. You've been most helpful. Take care.VimyJ wrote:Your problem could be the motor but most of the problems seem to be with the regulator. Professor Mike does know his stuff, though. I was wish I could help you but so far (kock wood) I haven't had a problem. I hope its your regulator because they're a great deal cheaper.
