autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Mon Jan 13, 2003 2:23 pm
On that model, make sure and check the start signal fuse in the fuse panel for being blown or MISSING. If this occurs what will happen is you will have to keep cycling the key and turning the engine over repeatedly until the fuel pressure builds up enough to start the engine, reason being the fuel pump does an initial run when the key is cycled from the Engine Control Unit. Seen several cases where the fuse was missing, and in the winter months, the hard start condition exist. I would start there.
