cunking »
https://forums.nicoclub.com/cunking-u213697.html
Sun Oct 19, 2025 6:58 pm
Need to replace the thermostat on my 96 Pathfinder XE (R50). Is there a gasket that goes between the housing and the cover? Or do you just use sealant? I don't see a gasket display in the Nissan diagram (do gaskets corresponding part numbers show up in Nissan diagrams??)
One Nissan agency mechanic says there is a gasket that comes with the MAIN THERMOSTAT HOUSING - but I am only replacing the THERMOSTAT HOUSING COVER.
A different Nissan agency mechanic says there is no gasket and just sealant is used to create the seal.
Any help would be appreciated!!
cunking on Sun Oct 19, 2025 7:37 pm, edited 1 time in total.
