Is there a antifreeze that protects to -85?
redwolf5514
Car: 89 240sx coupe ka24de swap. soon kadet!
Looking for an anti-freeze that can protect up to -85 for an idea i'm working on
WDRacing
Well, you can simply add denatured alcohol to the mixture, thats all they do. Alcohol doesn't freeze. The purer the source the better it will resist freezing.
turtl631
Car: S14
Actually, everything freezes, but some things just do it at incredibly low temperatures. Think nitrogen or oxygen..
redwolf5514
Does denatured alcohol corrode aluminum? It's been a long time since chemistry, how much do I need to add to 1 gallon to drop its freeze point by 20 degrees (form a -65 freeze point down to -85)? Or could some one give me the formula so I could figure this out.
It might be better for me to go and buy a Refractometer but I can't find one that goes that low, usually stops at -60
Modified by redwolf5514 at 7:13 AM 5/9/2005
WDRacing
I don't know how corrosive it is, but I've benn injecting it into the motor for years so...
Your on your own with equation, whats this for if I may ask.
redwolf5514
Idea I had one day wile working on my cousin’s car.I'll e-mail it to you tell me what you think and when I have all the bugs worked out I'll post it if it is practical or not
redwolf5514
so WD what do you think?
WDRacing
Its been done already man, Cryofuzion...
nismofly
Car: 89 Nissan 240SX Hatch
what is it if i may ask?
i may need something that can go that low just for normal driving next year if i decide to try and drive my car on the days when its that cold
redwolf5514
Cryofuzion uses CO2 to chill intake airmy idea was a little differant. It was to use CO2 as a chiller for the liquid inside an air to liquid intercooler.
redwolf5514
holy crap! It actually gets that cold in N.Y.! WOW! The coldest I can remember around Chicago was -45 back in the early 90's.
WDRacing
It never hits -40 anymore that I know of...Maybe the part of NY that touches Canada.
WDRacing
Another idea is to use dry ice instead of regualr ice to cool off the water.
redwolf5514
I was thinking about that to but I can find CO2 a lot easier than dry ice. Plus I could turn CO2 on/off from inside the car. I could run a smaller reservoir tank because I don't need a lager filler opening to pour in the ice. I could adjust the temp to what I want when I want from inside the car no need to get out and go under the hood.
