NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Jul 29, 2003 2:04 am
yes i believe that is the primary reason. but i have replaced a handful in the trucks but noticed the trucks i did had hitches on them at least most of them did.
not just the VG on the truck has this problem but it is pretty much just the VG30 that has the problem. the J30 maxima all D21 with VG engine all WD21 with VG the V40 also had this problem. any of the VG30 engines with the 8mm studs seem to have this problem. I have a fix for it but have not been able to do any real R&D to determine if the repair is life long or not. if you just replace the 8mm studs and manifolds it is fairly common that it will happen again after a few years. my fix is risky but very effective. you make the 2 holes mentioned in my first post to fit a 10 mm stud from a VG33 engine or a Z31 engine.
