BIGGEST myth about a RB swap. the "weight distribution" has an overall change of less than 2% going from 52/48 to 54/46. thats less of a balance shift than the difference between a full and empty tank of gas. the majority of the weight change in a 25 swap is the transmission, wich is more centered in the vehicle so the balance isnt that effected.maxima278 wrote: Or does the weight distribution hinder them?
anyway, be carefull when reading stuff like that. that RB25 from venus is probably just a motorset. you still need mounts, wiring and a driveshaft. minimum 500$ for those 3. not to mention all the intelligent replacment parts you should purchase pre-swap. timing belt, water pump, clutch, hoses, etc. theres another 500+maxima278 wrote:thanks for the info. Actually, I've seen one website (I believe it was venus motorsports) who was quoting RB25s $500 cheaper than SR20s. That will make the choice even easier for me if I find that scenario when I have the money for a swap. Of course when you add a $275 set of engine mounts that comes close to offsetting it plus whatever you have to do to the driveshaft (*maybe someone can enlighten me on that*). But still if the cost is equal or even a little more, sounds like the RB is well worth it
s14brent- welcome to the poor and broke wishing we had rb25s club. I just started it.
lets talk. more proof. show me hard proof why they arent good for drifting.MainEvent212 wrote:no, they are not good
stick w/ the KA24 or an SR20...there are reasons why they came in these cars
you guys just cant seem to get it through your heads!accel junky wrote:I wonder how the RB20 will be weight wise. I dropped the PWS and AC and all related components. And with a significantly lighter trans than the Rb25, it might be ok.
There is a guy on here that drifts his RB20 s13, and he has some cool vids somewhere.
Milano and Slide Squad Mark seem to do just fine with theirs. Rb's seem to be plenty happy bouncing off rev limiter all day. Only drawback I can think of was one track event I heard the driver was complaining that 3rd gear was too tall forcing him to use 2nd which did limit his speed as he ran out of revs real fast in 2nd.maxima278 wrote:Nobody seems to be drifting in 240s with RBs
sdtouge wrote:dont be mad. he is a good driver, one of if not the best on the site, he said it made a difference, he could tel. end of story.
listen to me, very closley.you are regurgitating hearsay or word of mouth. not FACT. you are young, so i will be civil. learn the difference between the 2 now, it will help you later in life.sdtouge wrote:right what
know what you are talking about. if you are questioning tanners driving, i doubt YOU are good enough to tell a differnce in weight, or are only able to drift bcuase of the extra power.
