Is the price on this G50 good?
MattB
Car: 2001 Infiniti I30A
http://www.autotrader.com/fyc/...dptop
$6995 for a 1995 Q45 with 76k...
Shave off a grand.
Rex
Car: None
Can't really tell without maint records.
Knowing if the car has be "kept up" and the condition of the knock sensors, the O2 sensors, if the plugs have been done, what the fuel pump sounds like, if the shocks/springs are in good shape, if the transmission is in good shape all play a big part in the price. Spend $100 to have an Infiniti master tech look it over and give you a "to-do list", use that as part of the negotiating process.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Rex wrote:Can't really tell without maint records.
Absolutely! Night pictures are always scary for me.
Couple of interesting ones on eBay, if you are quick. Haven't looked at cars.com or autotrader in quite a while.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Its worth it if you know the maintenance and it doesnt really need anything.... IMO low mileage Q really arent worth more than higher miles because they dont wear out.. all it gives is less room for other owners to screw stuff up...
If the car doesnt need anything immediately to be considered good (shocks, upper links, brakes, tires, KS, O2, et etc) then its worth it... bottom line is, i doubt it.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
It seems a bit high, unless the guy just replaced the struts, tension rods, upper links, brakes, knock sensors, plugs, valve cover gaskets, window regulators, tires, MAF, fuel pump, and the car is dent free.
I bought Lola from a meticulous person. She still needed $4,500 in "upgrades" to be "road ready" for me.
Just don't spend too much for clean paint and interior.
Tan interior seems to not last as well as other colors, for some reason. About 50% of all Q's for sale out there in the 94-95 range seem to be Green
