c-rad wrote:Is this possible?
Yes, it will run on open loop. Meaning it will run on the base maps without the correction of the 02 sensor. Your car runs on open loop for the first few seconds or minutes (depending if the 02 sensor is heated or not).
If you disconnect it with a ECU that requires a 02 input, it will throw a code.
c-rad wrote:Also, if you were to run a .bin file from a non-catalytic car, would that eliminate the need for one as well?
Well, that is a bit of a trick question. If the bin file can disable the need for 02 input, you will run on open loop and not have code. Just because it does not have a catalytic convertor, does not mean it does not have a 02 input.
