Is the HKS F-Con Worth A Crap?
Shawn Watson
I bought a old HKS F-con on ebay. I only bought it for the wirring harness that all the old HKS products came with. They have wirring harnesses that plug in between the factory ECU and Main Wirring harnness. Keeps you from having to cut you main wirring harness at the ecu when installing piggy back computers.
I was wondering however how good these old things are? I would be using it with a HKS GCC. Do all they do is up the injector pulse? Can't you have HKS burn you a new chip to compensate for larger injectors? Can you still get chips for it?
WOuld it be worth it to buy the GCC an use the F-con or just use the wirring harness i bought it for and a E manage?
ThanksShawn
Shawn Watson
Does anyone know? Or know where i could get some info on it?I am trying to figure out where i should use it or not.I already tried HKS's web site but didn't find anything i didn't know.
ThanksShawn
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
if you dont wanna use it, ill take it if its free or really cheap. sounds like it might be fun to mess with.
Shawn Watson
well i am trying to figure out if i wanna use it myself but no one seems to have any info on it at all.
ThanksShawn
themadscientist
they work just fine and yes you can have a chip burned for it. That is what makes them obsolete though. You have to find a shop that can program the chip for you. HKS still sells chips, harnesses and main units. I have two left, anybody want to buy them?
r34 gtr
if theyre dirt cheap, maybe, whats your price? im sure i could scrape up the money if i feel its worth it
themadscientist
$100.00 each shipped. One is for an RX7 and the other is for a Levin. They can be set up for any car with the proper harness and chip. I can purchase and install these before I send them for whatever the parts cost me. about $100.00 for the harness and $200.00 for the chip, takes about five minutes to do it.
So $100.00 for it as-is or $400.00 configured for your car with the off -the-shelf HKS maps on the chip.
r34 gtr
well, i might be interested, but i need to rebuild the turbo first, ill let ya know if i still want one in about a month
Shawn Watson
Well how would it compare to a Greddy E manage. I have one on my Z and you can do just aobut anything with it. Close to getting a stand alone as you can get with out the stand alone price. I really don't need all that adjustability though. I like the fact that it's plug and play. I would however get a GCC to control it a little better.
If i do decide to keep it can you get me a new HKS chip for it? I have no idea what chip it comes with. I have every thing else though.
ThanksShawn
themadscientist
what's wrong with the chip in it?
Shawn Watson
well i have no idea what modifications it will come with. I know its for a SR20 but don't know if stock inj. or not.
I guess i will have to crack it open and see. It should say on top of the ROM if i am correct?
ThanksShawn
themadscientist
leave the chip in and have it burned for your car. The chips are physically the same it's just the data that's different. If you bought it from HKS you would have a jack-of-all trades chip but you can't know what has been done to this one so it's best to assume it needs a re-write.
Shawn Watson
Where can i have it re-written? Do i have to go to a HKS dealer? How much does it usually cost to have it re-written?
ThanksShawn
themadscientist
I would think most shops that are HKS authorized dealers would be able to burn VPC or F-CON chips. I have no idea how much it costs I have been in Japan for almost ten years I'm behind the power curve on what prices are in the states.
slw240sx
Car: 1990 Ca18det 240sx Hatch
any one want chips burnt for a CA18det, i have JWT norris deisgn (soon) and a few other tuner chips that can be made for yah cheaper then they charge
Shawn Watson
Well when i had one burnt for a VPC for my white Z it was around $75 i think. But that has been quiet a while ago.
thanksShawn
themadscientist
it's the same software so check with the guys who did your VPC.
Shawn Watson
They had to send it to HKS. I guess i could do that too.
Anyway i guess i am going to use this system with a GCC but i really havn't heard any pro and cons about it.
ThanksShawn
