not so sure on the confident part. but i am the only there is to do it and it needs to be done so ill give it a shot.moso wrote:the cam has a different grind on it so you may want to switch them out but its not required, and there may be a few sensors that need switched but if your confident you can swap out the long block than you should be able to manage the rest. just dont throw anything away!
