is the Garrett T3super60 a good turbo for 250- 270whp Rb20?
blues14
Car: 1995 Nissan 240SX GTS-t
Like the topic says. is the Garrett T3super60 a good turbo for250- 270whp Rb20?
SeVa-S13
Car: '05 GTO 6spd
I don't have time to map a chart for you right now, but my guess would be yes, especially if it were .48/ar.
jdmser
Car: duh
The super 60 would be out of it's maxium efficiancy range about 3/4 of the way before redline according to the map on here http://www.turbofast.com.au/turbomap.html
rbosacco
Car: 97 discovery1, 99 yukon, 97 240 rb26 in progress, 72 280se benz 4.5, 03 gti, 98 vr jetta chump car, 91 straight axle 2500 suburban, 00 f350 super duty crew cab 4wd, v70 volvo wagon and a built warrior
just get a good used rb25 stock turbo and turn up the boost a little and get the car tuned. my rb25 makes 310whp and 325tq at 10.5 lbs of boost.
Shocker
Car: 89 240sxHB rb26/30
rbosacco wrote:just get a good used rb25 stock turbo and turn up the boost a little and get the car tuned. my rb25 makes 310whp and 325tq at 10.5 lbs of boost.
dont really want to call BS on you... but 325 wtq? I find that extremely unlikely.... especially at only 10.5 lbs on stock 25 turbo, I made 251 wtq at 11 pounds with mine.... something seems off.....
He is right though, 25 turbo will get you to around 250whp at 10-12 psi.
blues14
I have a S1 Rb25 turbo in my garage, but most everybody says its a waste of time and that i should buy a "REAL TURBO"
SeVa-S13
Car: '05 GTO 6spd
Well they do have a ceramic turbine wheel notorious for failing and you'd be pretty much maxing it out to get your power goal. The spool can't be beat though....
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
blues14 wrote:I have a S1 Rb25 turbo in my garage, but most everybody says its a waste of time and that i should buy a "REAL TURBO"
There right, Rock the Super 60 it might hit your power goals. If not step up to a T3/T4E 50trim with a .63 exhaust housing
