Is the FICD necessary?
Rubyz32
Car: 90 n/a z32
No mods as of yet
After performing the tests in the FSM, I have decided that my FICD valve is not working properly. When it is plugged in, with the screw turned all the way in and the IACV unplugged, the idle sits around 1300rpm.
I have no a/c. Can I leave the FICD unplugged without causing any damage? I have the idle adjusted to a very smooth 750. I plan on replacing it eventually, but funds are low right now. Thank you.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Necessary? No. Helpful? Yes. It also helps bump the idle for power steering.
ThisIsSparTTa
Car: 91 300ZX TT 2+0
http://z32.wikispaces.com/Idle+Control
You should be able to find one used off someone for cheap though. I'd just replace it.
