Is the diff side Bolt pattern diameter and size of 2002 q45 same as 1991 q45?
Alv8l
Car: 1991 Q45
I'm using a 350z wheel hub for my custom project which i believe is 29 spline. I have the 1991 q45 diff with 6 bolt evenly spaced differential flange. Does the 2002 q45 cv axle have the same diff side bolt size and pattern diameter as the 1991 q45. I believe they are both 6 bolts. Thanks.
This may be an occasion where it's best to order one (from a place with a good return policy) and double-check it.
I suspect most F50 owners (and there aren't many) have never looked under their car. :)
Alv8l
Car: 1991 Q45
Thanks that may be the way to go.
