The answer is yes, if they try to drive their cars like that. The "slammed" look is strictly for show, not go.KnuckleSandwich wrote: My question is, do those who run extreme camber to lower their car find that they have to buy tires more often?
You must know something Adrian Newey doesn't because RBR got their camber levels relegated in 2011, as they were running in excess of 4+ degrees. Considering the RB7 was the most dominant vehicle on the planet since we were graced with the F2004, and Adrian and Rory are probably the the two best vehicle engineers since the invent of such, you probably have race teams beating down your door =Pfloat_6969 wrote:In a perfect world with perfect suspension, you wouldn't need negative camber. Negative camber is used to offset the positive camber that is usually gained when a vehicle corners. Ideally, you only run enough negative camber so that when you corner hard, the tire doesn't go past about -.5°. For most vehicles that have been modified, they are running stiffer springs, and anti-sway bars. Both of these things help to reduce sway, and so reduce the need for negative camber.
To translate, flohtingPoint is saying that the Red Bull Formula One team had some success pushing the limits of negative camber. But that was a fairly specialized application for severe cornering on a race car. An application where tires are replaced after x number of laps. But in terms of an ordinary street vehicle used on the street, without a big budget for tires, the manufacturer's recommendation for caster/camber settings will almost always provide the best tread wear. Any drastic camber changes will definitely shorten the tire's life.flohtingPoint wrote:You must know something Adrian Newey doesn't because RBR got their camber levels relegated in 2011, as they were running in excess of 4+ degrees. Considering the RB7 was the most dominant vehicle on the planet since we were graced with the F2004, and Adrian and Rory are probably the the two best vehicle engineers since the invent of such, you probably have race teams beating down your door =Pfloat_6969 wrote:In a perfect world with perfect suspension, you wouldn't need negative camber. Negative camber is used to offset the positive camber that is usually gained when a vehicle corners. Ideally, you only run enough negative camber so that when you corner hard, the tire doesn't go past about -.5°. For most vehicles that have been modified, they are running stiffer springs, and anti-sway bars. Both of these things help to reduce sway, and so reduce the need for negative camber.
Ha, I see what you did there. I've actually never seen a cambered out S2000. Maybe people where I'm from just have class? I always see the VIP guys cambered to the max.gwoods wrote:That extreme camber on the street is reserved for Honda S2000's only
I honestly can't believe there aren't tires made for this. You can get colored-smoking drift tires and other niche stuff. The curtain-having VIPtards would be all over tires like that.elwesso wrote:The people who run extreme camber might as well motor cycle tires.. At least on a motorcycle tire there's tread up the sides..
You're the one who said, "In a perfect world with perfect suspension, you wouldn't need negative camber." Street cars don't exist in a "perfect world" and definitely DO NOT have "perfect suspensions". I provided a perfect world/perfect suspension, and that utilized a significant amount of negative camber.float_6969 wrote:I assumed we all knew we were referencing street driven passenger vehicles that might seem some track time on the weekends.
As with all things automotive, what you do with a street car is generally the opposite of what you do with a dedicated race car. I'm not claiming to be any kind of suspension expert, but I have enough race experience with street cars (autoX mostly) to know what you're trying to achieve.
Thanks for derailing the convo though
Nothing says Hon DUH like +8 degrees yo shout JDM and give me a double fist pumpAce2cool wrote:Ha, I see what you did there. I've actually never seen a cambered out S2000. Maybe people where I'm from just have class? I always see the VIP guys cambered to the max.gwoods wrote:That extreme camber on the street is reserved for Honda S2000's only
Got none of that from his post Joel. He's even the one who brought up autocross.Bubba1 wrote:Jim. I think you two are simply talking about different applications. In autocross or Formula 1, where tight turning is a key component and long term tire wear is not, you are correct that extra negative camber past manufacturer's settings is a good thing in the right amount. But in a normal street application, which is what Float, the OP and the rest of us were discussing, where tire wear IS a factor, that additional negative camber will wear out the tires prematurely.
That doesn't have tire wear anywhere in there, just misguided facts about modified vehicles and camber effects in hard cornering, not daily driving. Sway and pitch of a car isn't normal driving, nor is the squat from such, which is one of the things you're looking for when you upgrade your swaybars/springs. Normal street applications have nothing to do with cornering hard, not pulling 1G going to Safeway. You are talking about tire wear Joel, but float_6969 certainly was not.In a perfect world with perfect suspension, you wouldn't need negative camber. Negative camber is used to offset the positive camber that is usually gained when a vehicle corners. Ideally, you only run enough negative camber so that when you corner hard, the tire doesn't go past about -.5°. For most vehicles that have been modified, they are running stiffer springs, and anti-sway bars. Both of these things help to reduce sway, and so reduce the need for negative camber.
Who is your brother in law? I would love to talk to him and pick his brain on why you think "you wouldn't need negative camber" on "perfect suspension" and what "perfect suspension" is. I do just about every national event on this half of the USA, so I'm sure we'll bump into each other this year (in fact doing two events in Ohio and four in Nebraska, which is fairly close to Kansas if he lives near you). We may already know each other, who knows? It would be interesting to see a national level autocrosser (a three time champion at that) that says that negative camber is pointless.float_6969 wrote: And my brother-in-law, 3 time national champion, and generally finished in the top 5, helps me set up my car.
Who is saying anything about 8 degrees? I said I run 2.7 on my FRC, that's a different planet of difference... We're having a legitimate discussion here, dont throw out asinine, flippant replies. Back up what you said, in a "perfect world" with "perfect suspension, you wouldn't need negative camber". What is the perfect world and perfect suspension?OK flohtingPoint, you're right. We should all run -8°so the car handles better
It is all going to seriously depend on SCCA National Tour/Pro Solo scheduling and the funding of such. I had a blast in 2010 and would love to be back in 2013, but it's going to seriously depend on finances.Bubba1 wrote:Yeah, I see you're playing with Corvettes these days. very cool.Do you think you can make Carlisle this year?
This is what I'm trying to communicate. Maybe it's not coming across?AZhitman wrote:Needing negative camber doesn't mean EXCESSIVE negative camber.
Let's not let semantics get in the way of honest dialogue.
The bottom line is that radically-altered alignment settings can and will cause premature and unnecessary tire wear. It's simply factual.
My brother-in-law is Ron Williams.flohtingPoint wrote:Who is your brother in law? I would love to talk to him and pick his brain on why you think "you wouldn't need negative camber" on "perfect suspension" and what "perfect suspension" is. I do just about every national event on this half of the USA, so I'm sure we'll bump into each other this year (in fact doing two events in Ohio and four in Nebraska, which is fairly close to Kansas if he lives near you). We may already know each other, who knows? It would be interesting to see a national level autocrosser (a three time champion at that) that says that negative camber is pointless.float_6969 wrote: And my brother-in-law, 3 time national champion, and generally finished in the top 5, helps me set up my car.
I'm very much enjoying the Vette, I had one of the front runners of the class nationally come out and drive it for me before I bought it and he said, "you need to buy this car". We've done some winter testing with the car and have another event setup for the third of next month to do more testing on it to further dial it in.
I know Ron, he's good folk, ran against him in a bump class at the Lincoln Pro Solo this past season. He still selling his red FSP car? Ask him to tell you about his 2011 Nationals experience, quite the exciting story with cars breaking and such, I was working in the announce vehicle during that time and had to track all the car hopping.float_6969 wrote:My brother-in-law is Ron Williams.
