float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Aug 01, 2010 9:00 am
Sort of. Remember that the reason that they use an idle control valve is that if your idle is set via a fixed throttle position, the idle is only going to be at that RPM at that load. If you turn on things like the headlights, A/C, Rear defrost, stereo, wipers, roll down the windows, ETC, your idle will drop. I don't have any idle control simply because it's not available with my standalone. One of the drawbacks for me is that I've lightened up the reciprocating mass so much that load has a very noticeable effect on idle. I have to actually set my idle at 1100 RPM with no load so that when everything is turned on, the motor still turns fast enough to maintain a smooth idle and not dis-charge the battery, which is about 800 RPM.
If I had a stock idle control system available I would use it. And actually, I did end up going back to the stock air regulator for the fast idle as it just works better than anything else.
