is the 5 lug nessicary?
spider_slayer
Car: S14 240SX
S13 240SX
is converting to 5 lug hubs nessicary for the z32 caliper upgrade?
nismofly
Car: 89 Nissan 240SX Hatch
it can be done, you have to get 4 lug rotors though, probably get 5 lug 300zx rotors redrilled, thats what most people do if they want to keep 4 lug
Hijacker
Car: '92 240sx Convertible
'94 F-150
either a)buy a set of redrilled rotors from one of our sponsors, or b)get a machine shop to redrill a set of Z rotors for you. Done.
ramrat
Do redrilling 5 lug rotors to 4 lugs cause any unbalancing problems?
Silvia007
Car: 93 Nissan 240SX SE Fastback
ramrat wrote:Do redrilling 5 lug rotors to 4 lugs cause any unbalancing problems?
Weight differences because of the drilling is too centralized, won't affect the balance of the rotor.
spider_slayer
Car: S14 240SX
S13 240SX
so i take it that if you wanna use the z32 brkaes you must have the z rotors. i really don't wanna do this cause my rims are 4 lug and i love them (7 spoke 18's baby
also i hear redrilling your rotors will cause some serious problems in the future like warping and cracking
Hijacker
'94 F-150
haven't heard anybody report cracking a rotor from having the lug pattern redrilled. Also, I have 4 lug Z rotors, and haven't had any unbalancing issues with them.
The only way I could see someone cracking a rotor is from overtightening their lug nuts, but then again, you run the risk of stripping lug studs when you do that.
spider_slayer
Car: S14 240SX
S13 240SX
ok, well i took a closer look at my rims a little bit ago and there are 8 holes for the lugs.....does this mean that my rims minght be able to fit a 5 lug patten?? if so why wouldn't there be 9 holes?? 4 for a 4 bolt patten and 5 for the other pattern??
Hijacker
'94 F-150
some wheels just have 8. your wheels will only fit a 4x114.4 bolt pattern. for some reason, some companies put a second set of holes in the wheels even though they're useless holes
jmauld
spider_slayer wrote: i really don't wanna do this cause my rims are 4 lug and i love them (7 spoke 18's baby
Have you tried a good set of pads? Not the crap you buy from Advance.For most people, a good set of pads is more then enough brake. I use carbotech pads, and they held up well to track use.
Quote »also i hear redrilling your rotors will cause some serious problems in the future like warping and cracking[/quote]You are most likely thinking about crossdrilling your rotors.
The rims with 8 holes are generally drilled to work with two different bolt patterns. Common ones are 4x114.3 and 4x100.
spider_slayer
Car: S14 240SX
S13 240SX
damn, i was hopeful for a second. i guess i'll stick with jsut pads rotors and lines
Dirtylou
Car: 1991 Nissan 240SX RMS13
Man, I feel overwhelmed by all the options for my brakes; 4 or 5 lug, Z or aftermarket, drilled or slotted rotors, redrilling rotors. I wish someone would just make a whole package for less than 500 clams that would provide excellent stopping power. Ok I'm done whining now.
spider_slayer
Car: S14 240SX
S13 240SX
lol, i wish ANY preformance part worth having could be had for less then 500 bucks
Chingon
Car: 1991 and 1992 hatchbacks
mine was less than 350, and that was 4 corners, mc, braided lines, and good pads.
nismofly
gooooooooooo i have to find a price like that for the entire setup...
msaskin
Car: cars, computers, skiing, mountain biking
It's called piece it together yourself.
My Z32 fronts cost a total of:Calipers w/ hardware- $150 from autozoneLines - $50 from splpartsRotors - $120 from stranoparts, +$20 for re-drillingPads - Hawk HP+, $100 or so
Total = $440, and I've got the hawk pads plus a set of generic cheap-o autozone brand pads that came w/ the loaded calipers.
~matt
Dirtylou
LoL...I'm too paranoid to do the ol' Autozone switch-a-roo. :/
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
my front calipers are rebuilt ones from advance, I just switched the pads for some axxis metal masters and have had no problems so far. the rears I got from a salvage yard, and no problem there either. I think I paid too much for the front calipers though... probably about 360 for some reloaded iron calipers. Not that iron is bad, they just weigh a brickload.
