MaineExport »
https://forums.nicoclub.com/maineexport-u157.html
Thu Oct 03, 2002 1:10 pm
On the s14... the larger fan is called a clutch fan. It is attached to a pulley and it will ALWAYS spin when the engine is running. It will spin a little slower when the engine temp has not enguaged the clutch... as the engine heats up... a bi-metallic spring bends more and more... the tighter it gets, the more the fan engauges and it will spin along with the engine. It will never stop spinning if the engine is running... just slower or faster. Your squeeky belt is an actual problem... either they need to be tightened or replaced. Or, possibly, you might have a bad alternator, ac compressor, water pump, power steering, or a bad pulley on any of them. No need to worry yet, just check your belts... and tighten or replace them accordingly. If it continues... then look into it further.
