barrigas14 wrote:best way to go imo is the same. 8.5 all around.
A properly setup RWD grip car should always wear out the fronts first. This is because braking loads out weigh acceleration loads by alot. The front also has the majority of the cornering load (which is were the excessive shoulder wear SmithSR was talking about comes from). As well as typically more aggressive toe and camber settings in the front.jdmfreak03 wrote:How's that?
What works on one car, similar or not, doesn't mean it works on another. Static weight distribution really has no bearing on tire wear.Def wrote:All E36 M3's I've seen properly prepped for the track wore out their rear tires well before their fronts, and the car has very similar suspension geometry to a 240SX.
You can actually generate more total grip in the rear tires on corner exit by applying throttle and also cornering at the same time. This tends to really wear those rears down.
The fronts shouldn't wear out that quickly on a ~50/50 weight dist. car if you aren't overdriving it and have a decent amount of negative camber up front.
Nismo_Freak wrote:What works on one car, similar or not, doesn't mean it works on another. Static weight distribution really has no bearing on tire wear.
Def wrote:I was just offering an example that clearly shows that well setup RWD cars can(and in my experience, usually do) wear the rear tires out quicker.
As for static weight dist. not affecting tire wear - it plays a huge role. Given any lateral acceleration quantity, the force provided by the tires on that end of the car have to directly counteract the centripetal acceleration of the mass of that end(not really, but close enough). More weight on one end almost always equals more lateral load on that end's tires during cornering.
Since weight dist. can drastically affect handling, different factors are going to come into play, but breaking it down traction into its simplest idea will show that the more weight on one end, the more lateral grip the tires of that end have to provide, which in turn equals more wear.
if you go the same size f/r, you would want the same size tire f/r so you can rotate them. If you want different tires sizes, you should definitely have different wheel widths.kppk1986 wrote:so should i go same size all the way around.. it would be alot more cost effective.. i was also wondering about tire sizes on rims?? can you put to different size tires on rims?? for example if the wheels are 17-8 can you put both 225 and 230 size tires on that wheel??
Nismo_Freak wrote:Once you corner though you have dynamic weight load, not static.
See my point?
