is RPS clutchs suppose to be...
xaznthaiguyx
Car: s13 Silvia
are RPS stage 2 clutchs suppose to be high engagement or low? but rite now its high, i dunno if its my slave cylinder should be rebleeded? i juss put the clutch on...
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Try adjusting your clutch pedal. There is a rod from the master slave cylinder that attached to the clutch pedal. The end of it is adjustable by loosening the nut and turning the whole rod. You can adjust it to engage where ever you like. Just make sure you keep it high enough so that it can still DISENGAGE when you press the clutch. Also do not adjust it so high where the clutch can not fully disengage. Best rule of thumb is to leave about 1/4-1/2" freeplay on the top of the pedal. Most clutches engage at the top of the pedal where they are supposed to. Some need adjustment of the pedal to get it where it is supposed to be. Follow FSM pedal adjustments.
