Is replacing halogen bulbs difficult?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Marconelly
Since EX35 does not come with HID lamps standard, I figured I might put some GE Nighthawk or Silverstar halogens instead of the stock ones, for low beams. User manual states that for halogen replacement you should contact the service department, which I thought was excessive, it should be something I could easily do.
When I opened the hood, I started to understand why they ask you to contact service for this. The chassis construction beams are running so close to the bulb mounts that it doesn't seem easy to do at all. Maybe I'm missing something here, is there some trick to replacing these, or do you have to pull out the whole front lights mount piece before you can access lamps?
flashzoom
ya, there is not much trick there.you can do it on your own. but it is not easily done.you do need to show some squeez into that tight space, or you need to take some of the parts apart.either way, its not as easy as it should be.
NJ_EX35
Car: Infiniti EX35 Journey w/Navi
I hope you have slim hands and high tolerance for pain! Its not that bad I just remember it being a non-pleasurable experience... key is to pull up the plastic/rubber molds around the light housing and you should be able to get in there. Just a lot of patience and manuerving.
jamesstock
Car: 2010 Liquid Platinum/Stone Journey
Diamond Cut IR Tint
ANyone here who's ungraded from halogen to HID on their EX35..I wonder if you can post some pictures here to guide us as instructions.
Appreciate that all!
ramprun
Car: Infiniti EX35
there is a post with picture and direction of how to install HID. you just need to look for it
lybrian1
Car: 2008 EX35
remove front tires open cover on wheel well then u have access to all the lights.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
