is rb20det saturated or peak and hold injectors?
rbpwr240
Car: 240sx
need to know thanks also what cheap injector upgrade can I do dsm 450cc? thanks guys
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
rbpwr240 wrote:need to know thanks also what cheap injector upgrade can I do dsm 450cc? thanks guys
your going to need the resitor box from the eclipse too cause they are low impedance injectors. well you would need 2 of the boxes and wire up the injectors.
BoostFab
Car: S13cp, S13fb, S14z
the rb20det is saturated ( high impedance ). there are many oem replacement injectors for the rb20det. ie: rx-7, supra mk3, etc.... you can also use low impedance injectors with resistor packs.
look here: zerothread?id=101028
rbpwr240
Car: 240sx
so wha
BoostsFed wrote:the rb20det is saturated ( high impedance ). there are many oem replacement injectors for the rb20det. ie: rx-7, supra mk3, etc.... you can also use low impedance injectors with resistor packs.
injectors can i get from the salvage yard mk3 supra turbo injectors 89-91 rx7 turbo injectors???? any help???? need to know asap.
atticus
what about mk4?thanks
240+civic=pimp
Car: s13/rb20det, 2002 WRX, 1994 Yamaha fzr600
Cheap Upgrade come on there is no such thing. GO big or go home!!!!!!!!!!!
hannibal
Car: Red Line to Glenmont
from a spreadsheet I put together from info on the net...
top feed hi impedencemazda FC NA 88?-91 460ccmazda FC turbo 88?-91 550cc7m-ge and 2jz-ge 315cc
top feed low impedencerb26 440ccca18det 370cceclipse/talon turbo(1g and 2g) 450ccstealth/3000gt 360ccwrx 02+ 420ccRx-7 84-85 680ccFC NA 86-87? 460ccFC turbo 86-87? 550cc
BoostFab
atticus wrote:what about mk4?thanks
mk4 are side-feed
there are lots of 550cc rx7 injectors that are high impedance, and top-feed
also look for Nippon Denso....
