IS ONE AIRFLOW BUTTON ALWAYS ON?
CORogue18
Car: 2018 Nissan Rogue
IS ONE AIRFLOW BUTTON ALWAYS ON? My wife says that the airflow (a/c heat) buttons (icons) on her new 2018 Rogue will not turn off. It just started doing so according to her.. One button is always on (icon light up). I did not drive the new Rogue and cannot verify if one of those airflow selection buttons are on and light up all the time by default or this is indeed an issue. Dumb question I know, but appreciate your time and help.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO!
What trim level? S, SV, SL? Manual or automatic climate control? If it's manual, then the light should go out when you turn the system off. I'm not up-to-date on the latest quirks of the newer models, but technically speaking on the automatic climate control one would expect the light to go out when you turn the system off.
Unless you're experiencing some sort of airflow issue I'd ignore it.
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
Yes the airflow light will be on no matter if you turn the system on or off. When the system is off, the fresh air mode comes on and will stay on until you turn on the system and switch it to recirculation mode. This is to help you indicate what mode you are in. Its very different, since it doesn't do in any other make and model. Its common in all 2nd gens, so you don't need to worry about it.
Return to “Rogue Forum”
