pampadori »
https://forums.nicoclub.com/pampadori-u628.html
Tue Mar 25, 2003 4:15 pm
brian, the oil is usually from three things....1, the valvecover vent will have blowby coming out under boost. the other end of this hose is on your intake and the turbo sucks it in. somewhat normal. if you have vaccum on that vent "t" at idle, its nothing to worry about usually.
2. the turbo seals will leak when they sit long. it should be minimal after a while unless the turbo is just shot.
3. the motor was tipped over during shipping, and oil ran down the valvecover "t" and into the turbo inlet.
high boost will usually cause more noticable blowby. almost every turbo motor i have seen, has had this oil coating. i would just track the amount. when a motor gets very worn, it can be asmuch as a qt coming out of the t during a hard run. thats a bad motor. (i had one once).
also, the black box that is plumbed into the vent system, looks like a catchcan...this is actually a oil separator and will greatly keep down the amount of oil. It must be plumbed correctly. the vent coming out of the block under the exhaust manifold must enter this can on the bottom, then the top of the can goes to the valvecover "t". just like it does from the factory. if you take that black box apart, you will see it is more or less a filter and traps oil from being spit up with the blowby air.
on a side note, blowby is normal...to an extent. shaun
