is my turbo good
214kka-et240sx
Car: nissan s13 silvia
ok i seen a guy that has the same turbo i have (t25) making more power (220hp) me (180hp) on ka sohc but i boost 10 wit no boost controler and he boost is 7 no biist controler so my ? is , is it my turbo or my actuator or feul tunning or wtf is it
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
umm hooked on phonics works well when asking a ?and there are alot of other variables other than the turbo what other differences do you have?manifold, fmic , maf setup? alot of variables
214kka-et240sx
Warped wrote:umm hooked on phonics works well when asking a ?and there are alot of other variables other than the turbo what other differences do you have?manifold, fmic , maf setup? alot of variables
same thing he has SAFC , fmic, walbro f/p, and stock MAF i have same exact thing
TheOne
Car: 93 240sx FB
he's asking you for more information on the setup.
btw a tune can do wonders.......even if it means a 40-50hp difference.
214kka-et240sx
ok i mean why is he boosting 7 when iam boosting 10 wit no boost controler does boost have to do wit a SACF ,or MAF
DontStopRockIt
Car: 1993 Nissan 24SX SE
Your turbos' wastegates could be set for different ammounts of boost.
He could be making more power than you because of his tuning.
I'm pretty much a n00b to turbos so someone more experienced should correct me if I'm off.
Nismo_Freak
Car: 89 Nissan 240SX
He could be running a bigger T25.
You have the tiny Z32 peice o-chit turbo that I wouldn't put on a CA if I had to.
214kka-et240sx
he has the same peice o chit i have and it's not tuned yet
Nismo_Freak
214kka-et240sx wrote:he has the same peice o chit i have and it's not tuned yet
Get a bigger turbo.
214kka-et240sx
oki fine
madbouncy
Car: 93 Mazda RX7 R1
Have you checked the condition of your motor? 180 with 10psi sounds low, even for a small turbo like the t25.
214kka-et240sx
madbouncy wrote:Have you checked the condition of your motor? 180 with 10psi sounds low, even for a small turbo like the t25.
well my conpression is at 150 all 4 pistons maybe turbo is bad already
madbouncy
If you think the turbo is bad you might as well go to a bigger one, even if the turbo doesn't turn out to be too bad you'll get the bonus of having a bigger turbo that you'll probably have wanted to put on anyways. But do get it tuned, for the sake of your engine.
214kka-et240sx
yea ,well thanks for your advice yea i want to get either a t28 or a t3/t04 so will see
