Brice Peters »
https://forums.nicoclub.com/brice-peters-u7744.html
Fri Oct 27, 2006 11:47 am
Well im almost finished putting in my blacktop sr20 into my coupe but I ran into a huge problem. When the engine was first put into the car before the drive shaft was installed, the transmission would go into the gears but would not go into nuetral. No matter what we did, the drive shaft would not spin independantly of the engine. Well after a while fiddling with that, the transmission would not shift into any gear but 5th or reverse. Does the transmission have some sort of lock on it, or is my transmission siezed? The front clip was 100% stock even the stock airbox and the turbo has zero shaft play in it so I do not believe that it was abused. The importer said it was rear ended in Japan, is it possible that the old driveshaft bent something inside the transmission from the accident? Any help would be greatly appreciated!
Modified by Brice Peters at 9:43 PM 10/28/2006
