240FeVeR »
https://forums.nicoclub.com/240fever-u634.html
Fri Jan 24, 2003 12:25 pm
Since i have a little experience with this myself, being that i had problems with this before, i'll share my experience.
I'll start by saying I believe you have idling problems.
The throttle position sensor is OFTEN mistaken. The black box you see there serves three purposes: Throttle position, Idle switch, and Wide open switch.
The connections you're missing is NOT the throttle position sensor, these three are for the IDLE SWITCH. Your throttle position sensor connection is the connection that runs off the bottom of the black box (which you stated was properly connected).
Your car DOES have a connection to plug onto the three pins you see (idle switch), it should be there somewhere, search for it and connect it. Sometimes the pin comes off and the connection gets loose. With your idle switch disconnected, you will definitely have idling problems, rpms fluctuating, comming close to stalling..etc. Since the idle switch isn't connected, it can't switch on the idle air control valve which serves to inject air at closed throttle.
The throttle position sensor notifies the ecu of closed throttle, open throttle, and wide open throttle by way of different voltage readings from the sensor itself.
