Is my TPS bad? 5.1 volts at idle?? Am i testing the right wire? (auto trans tps)
redsx13
Car: 93 240sx 03 350z
So i think i finally figured out my problem. I checked my TPS today, and the signal wire (the white one) is making 4.6 volts at idle, and 5.1 volts at w.o.t. my car is a manual but my car has an automatic trasmission TPS and the are like 6 wires, am i testing the right one? Also if i do have to replace it, can i use a tps from a manual?
redsx13
anyone?
i just want some conformation before i go out and try to find one.
also, i have heard that the nissan sentra S-ER, 200sx and 95-98 240sx all have tps sensor interchangeable with the sr20det. can any one confirm this as well?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
If it's changing with throttle position it's the right one. Just double check that the other ones are a constant 5 volts and a ground reference.
redsx13
the converted wrote:If it's changing with throttle position it's the right one. Just double check that the other ones are a constant 5 volts and a ground reference.
Like i said there is a bunch wires because its an auto tps, but im pretty shure i have narrowed it down to which ones are the ground (black), power (red, and green red stripe on the harness [5v]), and signal (white).
i checked the resistance of just the tps with an ohm meter, it was reading over 50 k ohms at idle and 2k ohms at w.o.t. Im pretty shure that means its bad, but correct me if im wrong.
shift_SRDETuser
Car: 1996 Nissan 240SX SE
why are you running an auto tps? they have two connectors--- I am running a ka throttle body for cruise and an sr20det tps from the old sr throttle body--- I would change to the s13 sr tps for sure.....
redsx13
shift_SRDETuser wrote:why are you running an auto tps? they have two connectors--- I am running a ka throttle body for cruise and an sr20det tps from the old sr throttle body--- I would change to the s13 sr tps for sure.....
My auto tps only has one connector, but it does have 6 wires. thats just what came on the clip.
I can go to a junk yard and pick up a tps from a 95 240sx, a 200sx, or a sentra s-er (correct me if im wrong).
do you think it will be worth it just to buy the tps for an s13 sr brand new.
shift_SRDETuser
The FSM tells you exactly what wires do what and they generally only have 3 wires. power ground and signal.... the auto tps does some different things....using two wires I believe for signal -- check the fsm.....
redsx13
will do
