rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Thu Feb 10, 2005 9:18 am
So here is the scoop:I have blown coolant hoses before. Twice. Empied the coolant system once, the other time I got it before it got bad. Since then, my temp gauge has shown that the working temp is higher than it used to be.
Ok, here is what I have found:-There is no coolant loss.-The coolant is clear-The oil is clean-There are no leaks-Radiator gets hot, but not overly so-Thermostat is new and working
Here is the issue:A few times in the last few weeks, the temp gague has been fine (resting about 1mm above middle on the stock gauge) then SUDDENLY (like in less than 30 seconds) the needle jumps to H. Now, when I have blown a hose, it has done this as quickly, but the needle goes past the H. In this circumstance, it stops at the H or a little before. It has done this 3 time. Twice, I was babying it (off boost, keeping it below 5k....how I normally drive) and once it happened right after I got on it (full boost, 7500RPM). All 3 times I have pulled over and snooped around to verify that there is no leaks, and after cool, I check the coolant level to see it 100% full and clear. So, since the coolant and oil are clean, I assume that my HG is fine. Also, since the motor never acts funny when this happens, I assume that since all coolant is accounted for, it must be the gauge that is wacky? Maybe the times I overheated the engine destroyed the sensor? Any thoughts? I need a few more supplies before my aftermarket water temp gauge goes on, but I have been meaning to ask this for a while. Thanks guys!
