oldmako »
https://forums.nicoclub.com/oldmako-u82911.html
Fri Feb 19, 2010 3:03 pm
Before you get all cro-mag with the starter, you might want to double check the battery. I realize that it's recent but that's no guarantee. I just replaced a 14 month old battery last week in my truck. I am as tight as a frogs @ss, but I don't skimp on batteries. It was a large expensive battery when new. It had a bad cell. Why I dunno, but it would behave much like your Q.
If the batt is good, verify connections are clean enough to eat off and current flow. The previous post about internal corrosion is excellent. I once bought a used boat and went to replace the connectors on both batteries. I started by trimming an inch off the old. Well, there was heavy corrosion under the insulation and this was with heavy duty heat shrink. I ended up re-cutting over and over until I had sacrificed almost a foot of cable before I found virgin copper. I ended up replacing all the battery cables. Marine cable is like $5.00 per foot so that was a very pricey operation.
At any rate, lots of electrical bugaboos to track down before you yank out the starter. Wouldn't it be a beeotch to toss a new one in only to have it display the exact same symptoms? Been there and done that.
Good luck and if you find out the culprit for sure please re-post. Inquiring minds want to know. Not that I'll lose sleep over it or become distracted during the act of inflagrante delicto or anything like that, but it may help one of the Qheads down the road and therefore be beneficial to the brotherhood. Gnomesane?
