I recently had a post about an aggravating noise in the drive train of my Miata. I got a few responses, read the suggestions and had some time today to really dig into a diagnose my issue. The jist of it is a metallic vibrating sound that is rpm dependent, but only when the car is in gear. Push the clutch in, the sound doesn't go completely away, but its not nearly as bad.
http://forum.miata.net/vb/showthread...hlight=frapjap
I R&R'd the drive shaft in the case that U-joints were the problem (start cheap, right?). Pretty quick job, not to hard at all- this car was really well designed. Took the car for a spin- same old noise. Brought it home and put it up on jack stands. Found a loose heat shield around my cat, banged it off and started the car, noise persists.
Then I decided to "drive" the car while it was up on stands. You can hear the noise emitted from the rear wheel wells and then follow it from the axle to the differential, then to the transmission tail shaft area. However, while revving the engine, the sound is more pronounced from the rear of the car. At 150k its completely possible that the diff is ready to implode on itself.
But, just for clarification, I've attached two videos.
http://www.facebook.com/video/video.php?v=877926182155
http://www.facebook.com/video/video.php?v=877922065405
A bunch of you folks here are far better mechanics and more experienced than I am, so if you have a moment, check 'em out, let me know if you think the rear is failing, too. (I'm fairly certain it is)
Thanks!
