is my lsd going bad??
ELITEBB127108
hey guys....im guessing my lsd is not working properly. i can do burnouts without a problem but when i try to do a donut or try to drift (TRY TO), i can feel the tires bouncing? or that non-lsd feeling. dont 91 fastbacks have them? and since i can do a burn out that mean i have an lsd right? dont know guys need help!maybe i need to change the gear oil?
zombieman
do a search real quick and you'll get your answer. you can do burnout with any kind of car.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
uhh...are you leaving 2 stripes? and why are your tires bouncing if you're sliding? when i'm sliding i just slide...and i knwo i have an open diff
ELITEBB127108
i meant like .....not litterally bouncing...but that feeling of not slipping....its like....grip, slip, grip, slip, on and on
jab11185
Car: 1992 Nissan 240sx
hmm...sounds like an open diff to me....that grip slip grip slip feeling is what i feel when i attempt to drift a dry or semi dry road...and i kno that i have an open diff....
ELITEBB127108
and....what is an open diff???
Fenvy
Car: 2005 350Z Base 6MT
ELITEBB127108 wrote:and....what is an open diff???
it means you might not even have lsd :P
http://www.240sx.org/faq/artic...l.htm
read and learn
Mr1der
can i just have your car?:D
Fenvy
can I have your thunder bird? :)
ELITEBB127108
oh....allright...i really didnt know these things...
Fenvy
what year is your car? chances are you don't have lsd. People pay big ones to get them. And about being able to do burn outs... I can do 2+ second burn outs on my integra easily thanks to crappy tires
marshun
no s13's have lsd. but umm... is this an s14? just wondering.
Mr1der
Loveless wrote:can I have your thunder bird? :)
I'd have to show you how to make everything work! it's so ghetto right now:D
but it's still got 300ft lbs of torque to play with:D
zombieman
Quote »no s13's have lsd[/quote]
tell me you're joking right?
Fenvy
supra hica s13s have lsd.
sycle
Car: 1989 240sx
he is right partially, only s13 with HICA's have lsd in the United States. The s13 in canada i pretty sure all had lsd, same with the ones in japan. I dont think the our s14 have lsd either, mainly because you never here about people going to the junk yard to pull the diff out of a s14. But most s13 do not have lsd(in america).
you can burn out without lsd
marshun
zombieman wrote:tell me you're joking right?
well these two have already said wich s13's do have lsd. but i was being vague :D
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
I mean since we're having such an educated discussion, would someone like to trade me their car for my pos...err umm 3000GT.
ELITEBB127108
i have a 91 fastback...hmm...i guess i dont have one...but what does the s14 have? can i just get the lsd from an s14? or should i just look for a differnt one? anyone know or have a reliable lsd?
Fenvy
you can generally get it from z32 (300zx) but for some reason mine came from r32
RalphCare
Loveless wrote:you can generally get it from z32 (300zx) but for some reason mine came from r32
all R200 diffs (j30, N/A z32, Gts-t R32) will work on s13 with correct output shafts and flanges.. some have 5 bolts, some have 3.that is your "some" reason :icesangel
PhaneSoul
Car: 89 Nissan 240SX SE Black 5spd Wrecked
95 Nissan 240SX SE Green 5spd s14.5 yay!
lsd meaning?
Fenvy
lsd, the drug you take and you get high
I already posted the link, click on ithttp://www.240sx.org/faq/artic...l.htm
Got_Nissan?
Quote »I dont think the our s14 have lsd either, mainly because you never here about people going to the junk yard to pull the diff out of a s14.[/quote]
Actually S14 SE's do have lsd's, at least some of them do. I found one at a junkyard with an lsd but it has abs. and the diff. a 1/4 inch longer because of the sensor so I can't use it.
