djsonic wrote:try checking the soldering job to the MAF, i had the same problem, turned out the soldering job was messed up, restripped and resoldered and fixed it.
I have the wires all unwrapped and the soldering looks to be held together good. Did yours look good too, and you just redid it anyways? Because from what I can tell its not that.
So far this is everything I've checked that I know isnt the problem-
ignitor chipcoil packsfuel pump fuel filterThe spark plugs I checked and they look to be good, but Im going to buy some new ones anyways. The gap should be .28-.33 right?
Nismo_Freak wrote:try getting some new NGK Coppers and gap them to slightly under factory gap. Put them in and see if that solves the issue. If not then you more than likely have a boost leak or a vacuum leak somewhere.
Do you think a vacuum leak would cause it to do this? My boost gauge is reading only 10-11 in vacuum when I have it hooked up to the big nipple to the upper right of the throttle body, but when I hook it up to the little one to the upper left of the throttle body it reads around 20 like its susposed to. Do you think that has anything to do with it? Also when I hook my BOV up the the bigger one it doesnt work, but when I hook it up to the smaller one it works fine. Its like the upper right big vacuum nipple above the throttle body isnt getting enough vacuum somehow. What would cause this?
